Re: 9.5 problem
I would follow Tashasdaddy advice as it will help, but I have a couple of 9.5's with about 65 lbs of compression, they all run great, albeit a bit slow for a 9.5. They are outputting about less then or equal to my 58' 7.5 hp johnson.
is it dying in a barrel or on the water? with hood on or off?
is the bulb staying firm or flattening out.?
when you did your carb, did you replace your float and "O" ring/washers on the low speed needle?
If you hadn't I would suggest buying a carb kit and doing the whole magilla again.
good luck and keep us posted on what your solution turns out to be.
