Timkenneyjr
- Jul 13, 2019
- 9
Ok so, I recently picked up a long time sitting 67 mq13b. Everything needed gone through, last attempt to start previous owner couldn’t get it to run on fuel, I’ve gone through the carb ignition tiller handle lower unit cleaned fuel pump out everything before attempting to pull the rope, (seized from years of sitting little clp does wonders!) after all this I have run into the same problem. If I put fuel through the top of carb she will run. Briefly. The primer will pump up, disconnected from the carb it will shoot fuel, fuel
I can also get fuel to the bowl manually through the carb inlet it seems. Now, I have swapped the fuel pump lines with clear lines so I can see delivery and it seems it pumps more air than fuel. Before I can get the fuel to the carb the fuel is trickling back down the line, and the bulb is tight, I have gone through the carb as I said with a mech at local marina and everything is good(rebuild kit on order anyway) however nothing else matters til I can get fuel fed in, it is the bigger old style fuel pump and I’m thinking that the fuel problem is related to the orientation of the pump and lines( someone tried tinkering previously) due to lines being wrong size and shimmed with cut line pieces I thought I had it figured out to be the issue but I’be changed them all and everything seems to be pretty well sealed off. It’s gotta be something simple but I have gone through all the forums and internet info I can find and can’t find anything on this kind of issue. If it’s the fuel pump I need to know why it’s the fuel pump if it’s the carb tell me why. I’m no stranger to repairing anything I can get my tools to and I have to understand what and why not just replace an hope, just one of my peeves I guess, pleas advise any and all much appreciated. I I can find out exactly how this pump is supposed to be setup and lines as well it would be greatly appreciated
