9.8 merc dies at high speed
BobG
I have a 9.8 merc 1977 model, that dies at high speed , but will restart immediatly after. I changed the rubber hose from the tank and cleaned the filter. Anyone have any ideas?
corm
Re: 9.8 merc dies at high speed
Have you tried squeezing the primer bulb when running to see if it is the fuel pump.<br />Other things, debris in the needle and seat,<br />bad switch box, broken trigger wire.<br /><br /><br />------------------<br />...have fun...corm<br /><br />cubic inches = power<br />power = speed<br />speed = FUN<br /><br />Email me if you need to.
12Footer
Replace the plugs, start it and run it to temp. Adjust idle after she's warm.
