crackedglass
- Jan 4, 2009
- 203
Over the past few years I've owned a dozen or more 1978 to 1992 model 9.9/15hp motors.
It seems that every one of these at one point or another needed the upper motor mounts replaced.
All were super clean freshwater run motors. The mounts just detached from their base.
What causes this or is this just a known issue with these motors?
I'm fairly easy on my motors, they don't get abused and are stored indoors.
I was using my 1990 9.9 on Sunday and one of the top motor mounts let go.
It wouldn't be so bad but you have to pull the power head, and lower unit to replace the mounts on these.
Between the cost of gaskets, new mounts, (I'd never just change one), and in most cases I put in at the very least a fresh wp impeller while the lower is off.
The gaskets alone were over $30 at the dealer, the two mounts were $85 each, and the water pump kit was $67. Its the first time for this motor but it seems every one of these I've owned has had those mounts either break or go soft. At nearly $300 in just parts it comes close to the value of one of these motors.
