Re: 9.9 chrysler
You might do a compression check...I don't know which cylinder operates the fuel pump...check the fuel tank vent make sure it is working, loosen the cap and if it works then fix the vent...remove fuel line to carb and try to start, should be a good stream of gas come out(contain the gas)...Make sure the fuel line is good...let us know how you make out
