Starts when cold.
Hard to start when warm.
I have replaced the following:
CDI
Coils
Ignition Wire
Everything under the flywheel
Thermostat
Sparkplugs
Impeller
Gear oil
Things that have helped:
Ultrasonically cleaned the carb twice.
Increasing the idle RPM
Adjusting the low idle jet.
Adjusting the float.
The components I've replaced were taken off a known working outboard.
The components that I thought were bad were taken off the original outboard, put on the known working outboard for testing.
Every component worked perfectly fine.
It was recommended that I check the crankshaft seals and replace them.
I get beautiful strong spark.
What's the procedure to set the sync - throttle cable and linkages ?
What else can cause this outboard to be so stubborn to start ?
