Dale Milne
- Feb 9, 2003
- 13
hopeing for so good advice. 9.9 gamefisher 1994 model 225-581-996 serial oeo36251. first time out it started with a shot of starter fluid and then ran great. after about 4 min it started to bog down then died. about this same time I started smelling rubber burning and the motor appeared to overheat and would not start back up. after about 20 min it started up ran good till i got back to dock (about 4 min again and had the same prob. I tried to start it in my yard and it poped a couple of times then nothin. there is a fair amount of oil in the barrel so it is pumpin oil out the exhaust. I checked compresion and one is 90 the other is 95 I have spark and fuel but will not start. the therm was not there when i opened it up so that is not the overheating prob. I am going to replace pump. what else could be causing the overheating and the failure to start now?
