I have a 9.9 Johnson Model 1077ELA. It?s a 1977, long shaft, electric start. It?s new to me last October and we only ran it in a barrel before we bought it. Came with the 1652 Monark jon boat. PO seemed very forthright about all things. He did say he had it serviced recently, spent $300, but couldn?t produce an invoice or give details about what was done other that new gear oil??. That?s all the history I have. Motor looks great though and very clean. Must have been stored inside. Even the cowling gasket is still soft and flexible.
OEM metal gas tank. Siphoned out the ? gallon the PO gave us and had a little sediment. Switched to one of my good metal tanks. Got the OEM manual off eBay over the winter. Put it in storage garage. Ohio winters......
This week, I changed plugs. PO had NGK and I switched to Champion QL77JC4. Compression was 95 psi on both cylinders. Ran a gallon of fresh gas with 8 ounces of Seafoam. Started and ran great. Good water stream. Very little smoke. So much for the history.
Ran the boat on a small lake with a 10 hp limit and ran good but I didn?t push it to WOT. Turned it over to my son to drive (it?s his rig) and soon after he trottled up it had a misfire about every 3 to 4 seconds. When he slowed down, it semed fine. I took over and gradually increased speed and ran fine again he he swears I was going as fast or fasted. Still never went WOT.
Only difference I see is that he may have been more aggressive with the throttle than me. Any thoughts?
WD
WD
