9.9 Johnson - where's the shift rod disconnect?
BigBand
So, I waited until the last minute to change the water pump impeller on my 2001 J10RVLSIC. What should have been a quick job seems to be taking too long, and a few hiccups to boot.
This is a long shaft model, if that matters.
I got the six bolts that hold the gear case to the exhaust housing out without any of them seizing. I got the gear case to drop down almost and inch, but I don't see any place to disconnect the shift rod, just a straight rod going up from the gear case.
What am I missing?
The connecter ( brass ) is right there at the joint.----------You may have the move the shift lever and pry on the lower unit to establish unuff room to REMOVE the upper screw.------------------On assembly make sure the notch on the shift rod is lined up before putting the screw in.------------Then it all goes back together and will shift properly.
Chinewalker
If I read your model number correctly, your motor is a long shaft. The coupling may be at the upper joint and will require removal of the bolts from the extension housing to access it as racerone has described.
BigBand
And that's where it was.
New water pump is installed and working fine. Thanks, guys!
:thumb:
