9.9 Merc only runs with choke on full
Weatherby
My 1995 9.9HP merc 2 stroke will only idle or run below 1500 RPM with Choke on full. Above 1500 it runs with choke off. Also, I must manual choke to start the thing. Any solutions? I did have a fuel problem in the past (some kind of slimy contaminant that clogged the filter). <br /><br />------------------
Bear
Re: 9.9 Merc only runs with choke on full
Did it work properly last time you used it?<br />It sounds to me that the idle cicuit is clogged.
balin206
I have a very similar problem with my 9.9 Suzuki. Did you ever find the problem? If so, any details would be greatly appreciated.
JB
Hey, Weatherby. Check out my reply to Balin's post, below.<br /><br />Good luck.<br />Red sky at night. . .<br />JB :)
