9.9 Mercury prop nut...
DVTO2
Got both motors ready and all ready to go out to tomorrow and I can't fund the prop nut for my 9.9 kicker. Can I get one at the hardware store is is it a special mercury part?
Fun Times
It's best to try and find a brass propeller nut. You should be able to find one at just about any local marine store. The part number your looking for is 11-40140 or 11-13914. If you can't find one in time, here is the size you'll need. Mercury Mariner 5-15 HP outboards using a Brass prop nut with M10x1.5 threads and nylon insert.
http://www.mercruiserparts.com/Show...nbr=210&bdesc=GEAR+HSG+(PROP+SHAFT)+DESIGN+II
http://www.iboats.com/Boat-Parts-Ac...0--search_in_category.f--session_id.751618635
If needed, here's your parts catalog to match your engine serial number. http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=811286
DVTO2
Thank you. I'm going with stainless steel today and I'll order a brass one, maybe two.
