9.9 SMOKING
gregs
IS IT BEST TO MIX FUEL AND OIL RIGHT TO THE T ? I WAS WONDERING IF MAYBE A LITTLE LESS OIL WOULD BE BEST TO HAVE A LITTLE LESS SMOKE. I'VE ALREADY ADJUSTED THE SLOW SPEED IDLE. IT SEEMS TO BE THE BEST I'M GOING TO GET. THERES NOT A LOT OF SMOKE BUT A LIITLE MORE THAN I THOUGHT THERE WOULD BE. THIS IS MY FIRST OUTBOARD SO IM REALLY NOT SURE HOW MUCH SMOKE IS ENOUGH OR TO MUCH.
FlyBoyMark
Ensign
Re: 9.9 SMOKING
Stop worrying about the smoke...and worry about the proper fuel oil mix for your engine. Most all 2 cycle smoke a little. They also tend to load up a little when first starting or idleling for a long time. This will make them smoke sometimes a little. NOT ENOUGH OIL MEANS FRIED, DEAD, SIEZED, BROKEN ENGINE. Most all containers of outboard oil tell you how much to mix. I surmise your engine is a newer engine that uses 50:1 or 16 oz. to 6 gal. of gas. Minus a 1/2 oz. at 6 gal. won't fry an engine rite away, BUT always use at least the min. recomended. A little tiny extra oil won't hurt but too much oil can make a 2 cycle engine run hot because there is less fuel and more oil thus the engine will run lean. That's why outboard manufactures recommend that you do not run WOT continuesly during break-in with double oil mix.
Fouled Plug
Ensign
Re: 9.9 SMOKING
FlyBoy gives good advice, Gregs. Smoke comes with the territory on 2 stroke motors. Use fresh 97 octane fuel, and mix to manufacturer's specifications, and your motor should live a long happy life. :)
Bob_VT
Re: 9.9 SMOKING
Don't you mean 87 octane? I heard that higher octane means higher carbon fouling.<br /><br />Bob
steelespike
Re: 9.9 SMOKING
If smoking really bothers you you could try artificial 2 stroke oil it is said to smoke less<br />and is more friendly to the inviroment. However<br />its not to friendly to the pocketbook.<br /> Spike
