9 amp to 16 amp stator overcharging
cam1399
Finally getting everything worked out on this motor. Stator was bad and thought it was the 16 amp stator but turns out it was a 9 amp. My engine only has the small square rectifier. It is overcharging the battery. Maxed out the gauge at 16 volts. I don’t want to burn anything up. Can I add a regulator or different rectifier to match the 16 amps? Thanks for all the help
cam1399
Thanks. I tried a used one off eBay similar to this one but it didn’t have the 2nd red wire
cam1399
is this a rectifier/regulator or do I still need my small square rectifier?
Dukedog
thats a 20 amp reg/rectifier combined.... they are used a lot on tha older stuff from what i hear....
Dukedog
we ran 16 amp stuff on our junk without a reg for many years without a problem... replaced a few rectifiers though................
cam1399
20 amp should work? 16 amps without regulator didn’t damage battery or anything by overcharging?
Dukedog
never did it with us... had a very good battery program and a coupla things (big fuel pump, tunes and such) that would pull a few amps almost all tha time tha key was on
1960 Starflite
I kept boiling the battery with my 1975 850 Merc. Voltage gauge was running at 17 anywhere above half throttle. Installed a 6 wire regulator, voltage now steady at 14.5v. You'll have to get creative with mounting.
