oldcatamount
- Apr 4, 2010
- 1,740
I have a 1990 4hp. Johnson that I can't get to start and I'm thinking the intake vacuum pressure is not strong enough. This motor has 95lb. of compression on both cylinders, the carb is very clean, the fuel pump seems ok, and the ignition is good.To test the vacuum pressure, I removed the carb and stuck a piece of thin masking tape (blue, painters tape) over the intake manifold opening and cranked the motor over while watching the movement of the tape. I could see the tape suck inward (slightly) as I pulled the starter cord. To compare, I have another (good running) 4hp Johnson ('69) and did the same test on that one. The tape seemed to react the same way on both motors. Is there a way to better test the vacuum pressure or, am I wasting my time with all of this?
