90-65 jet impeller
pa. jet
just bought a 90-65 johnson jet model j90jlets and want to change water pump impeller.my question is does standard 90 hp impeller on this site fit jet model? any input on this motor i always ran mercs thanks
HighTrim
Re: 90-65 jet impeller
That is a 1993 90 hp Johnson Jet Drive, Long Shaft
tashasdaddy
to be honest i don't know, but i don't think so, can not find diagram for that motor.
HighTrim
The impeller is part number 0435821
Whole water pump kit is 0434421
Copy and past the link below, then follow the prompts to your motor. The jet drive unit will be in the list of components, under intake manifold.
"http://shop2.evinrude.com/ext/index.aspx?s1=32f3ee7c4b50b5cc7d8eb84bcc326e69"
Here is the Sierra impeller from here on iboats.
http://www.iboats.com/mall/partfind...gd_poid=109123&gd_row=83&**********=571350740
HighTrim
Just go to the normal 1993 90 hp, then under components there will be a column for jet drive, underneath intake manifold.
