90 amp starter fuse question
kyboater3466
Okay instaling 90 amp fuse for safety reasons mounts to starter does battery cable mount to other end with the nut looks pretty small for battery cable end. Thanks bought boat with it missing
Bt Doctur
Re: 90 amp starter fuse question
the main battery cable goes on first, the 90A fuse is next ,the orange wire next and your done.the main system power shoud be a red/purple ,that goes to the small end of the 90A fuse
kyboater3466
Thank You, but i ran across a electrical diagram that showed the orange wire from the alternator to the small end of the fuse, hate to question you but just wanted to make sure
Don S
It would help if we knew what we were working on. You asked a vague general question, and got a general answer.
Don S
Do you have a volt meter or an ammeter on the dash? Is one of the 3 wires (if you have 3 wires) orange?
kyboater3466
Volt meter the two wires on the back of the volt meter are red and black, i have a orange wire coming from the back of the alternator over to the starter.
ENSIGN
The orange wire and the red wire with a purple stripe connect to the small terminal on the fuse.
Don S
  • #3 Engines All 78-84 405.pdf
