I replaced my 115 on my boat with a 150 and it hasn't run right since I put it on. It only seems to like starting on 3/4 throttle and starts in a cloud of smoke. After idling for a while to get good gas flow i can shift and start slowly but then after pushing to full throttle to it bogs slightly then starts fast then bogs again and then starts and goes properly.. it will go up steady in acceleration but only if i ease the throttle open.. also when i shut down the bulb doesn't seem to maintain pressure.. so upon shutdown i have to press the bulb back to prime and start at 3/4 throttle again... is this a fuel pump issue?
