90 Evinrude 115 powerpack
DavidD
Has anyone ever seen a powerpack that would only send power to 3 out of 4 coils? Every bad pack I have ever noticed wouldnt fire any of the coils.
DavidD
Re: 90 Evinrude 115 powerpack
Thank you Bob!!! Never knew this existed!!!
175se
ive seen two and both weren't firing #4
boobie
Switch the coil with a good cylinder once and see what happens. Also a Model# would Help!!
DavidD
I have swapped the other 3 to this position and none will fire. it is the top port cylinder have also swapped plugs as well. J115TSLEUA
boobie
Read post# 2 again and check with them. I'd have to guess a bad power pack. JMHO.
Faztbullet
Well first your motor is a 97 model and has the single pack. These are very bad about dropping cylinders due to being damaged by inductive kick back from coil to switchbox. Replace the wires with the new grey suppressive wires(CDI) and replace thatt coil on that cylinder if you remember which one it is.
johnson89
yes I had a bad coil,that messed up a powerpack ,would only fire on 3 cyl.s,,,,replaced all 4 coils and a new powerpack
