90 force 120hp single exhaust
roscoe
Re: 90 force 120hp single exhaust
For the ignition switch? <br /><br />Accessory purple<br />Battery red<br />Choke yellow/black<br />I would be the same as A, are you sure it isn't another M?<br />Magneto (two of them) black and black/yellow<br />Starter yellow/red<br />tan/blue is the overheat signal<br />gray is the tach signal<br /><br />If you need it for the motor ignition components, your probably gonna have to buy a manual or borrow one from the library.<br />Seloc or Clymer manuals are good.
fwbeachyacht
thank you but i was hoping to find a color coded diagram of all the wires - am lost - did not want to buy a manual for one boat
roscoe
Pretty hard to type all the info in for 50 wires, and you will need to see the pictures to fully understand.
