90 H P 04 Mercury No warning module?
KeithPumilia
I won this motor on ebay and installed it myself. But was told that when I first turn the key on it should beep to confirm it is working . When I investigated , I noticed the oil tank switch and temperature switch are connected directly to the warning buzzer. Is this right or am I missing the module? Also I am missing the tag which tells me the proper spark plug and gap dimension. I found out the plug ,but not the gap size.
achris
More fish than mountain goat
Re: 90 H P 04 Mercury No warning module?
Hello Keith and :welcome: aboard.
From what I can see on the drawings and circuit diagrams, you're quite right, no module. The module is used on the V6s, as they have a rotation monitor on the oil pump shaft. The drawings show your engine to have the oil bottle switch and the over heat switch hooked together, just as you described.
Spark plugs should be BUHW-2. These are a surface gap plug and don't have an adjustment for the gap.
Chris.........
10bender24
My 04 125 is the same way, no audible alarm.. The oil switch and temperature sensor go to a rev limiter, if there is a fault it will start missing..
kmagnuss
My 07' 90 has an audible alarm.
ondarvr
My 05' 90 has an audible alarm, but no beep when turning the key on.
kmagnuss
Mine beeps whe turning the key on and when oil is low. Not sure on overheating and hopefully won't ever have to find out.
