peter wickham
- Feb 5, 2010
- 41
outboard has recently developed water in one cylinder. was slow to run properly on initial start on two occasions and on last use would only run on 3 cylinders till i changed plug. (found water on plug). ran ok for rest of trip. But removed head after flushing and found signs of water in cylinder. Gasket looks ok head looks ok and cylinders look ok. I am hoping that the problem is the gasket, but as it is a new problem and only a minor leak its not yet showing on head gasket. Have cleaned everyting up ready to reassemble. What is the head tension and also I have read to use a sealer on gasket, but in this forum it said not to use sealer. I was going to use Hylomar. Now Im not sure. I am also unsure of my diagnosis. Prior to this problem a thermostat was stuck open and was replaced, and also the water pump impeller replaced. [minor rust stain in cylinder]**:juggle:
