richforfish
- Mar 24, 2013
- 4
Just got this boat. the first thing i did was to add a tell tale but no water came out. next a new pump, still no water.removed the lower unit and the thermastat cover connected the garden hose to the bottom of the water pipe and turned on the water on. with the motor tilted about half way up, still no water getting to the thermestat housing.i can look up the exhaust port and see the water running back out around the top of the pipe as far up as i can see. could a bad grommet under the powerhead leak this much? does the pipe come out through the bottom or top?
Thanks,Rich
Thanks,Rich
