I have a 1990 70 hp 2 stroke johnson 3 cylinder I replaced the #2 cylinder ran oil in fuel and vro as prescribed engine idle perfect timing top and bottom dead on. got to lake # 3 carb float stuck at dock took a few minutes to figure out and fix. The engine now runs rough at idle but smooths out at about 1500 rpm. after running for several days engine progressively running better switched to regular gas after 10 gallons of fuel. Still rough idle. #3 piston good compression #2 a little less #1 a little less than #2. Now granted this is thumb over hole test. Looked in cylinders through spark hole they are mirror clean. Pulling the wire when running backs up thumb over hole results. I know I can damage ignition.
It runs like a scalded ape I took it to full throttle after about 8 hrs of break in time. My question is Did the # 3 cylinder seat because of the extra fuel it got when the carb over flowed and is it normal for the pistons to take a while to build to full compression? It seems the more I run it the better it runs so should I just ignore the compression thing and just run it.
This is my first boat
