I bought this boat a month and a half ago and the tach hasn't worked since I bought it indicating to me the Regulator/Rectifier (R/R) was on its way out. It finally completely fried itself in a plastic oozing almost electrical fire kind of way. The yellow leads from the stator were burned (prior to the R/R failing) so I replaced them and several of the other connections going to the R/R. I replaced the R/R with a CDI unit. The tach now works and it seems to be charging. Although I have made one observation: With my multimeter leads on the battery connection points at the motor the voltage varies wildly between 12 v and 18 v. At the battery it measures 13.XX volts at idle and jumps up with throttle input over 14 volts. Also, I popped the cowling after a 30 minute ride and the R/R was too hot to touch which was concerning.
My questions are as follows: Should I worry about the R/R being too hot to touch for more than a second or two? Also should I worry about the varying voltage at the motor side battery connections? Do any of these indicate stator issues?
There are no visible signs of the stator being burned or oozing from looking up under the flywheel (I haven't actually pulled the flywheel yet). The manual was not very clear about how to check the stator battery charging coils. I would like very much not to burn up another R/R at $130 each.
Thanks in advance for the advice!
