90 HP etec 2016 injectors
1tomtom
Had my injectors cleaned one was bad the new one they sent me was part #5008886 from what I’ve read online they discontinued that part number for this model etec but they insist it’s the right part for my etec I had installed it downloaded the software and doesn’t run correctly. After researching the part number was changed 5010221 is there a way to confirm that #5008886 is the correct injector the injector doesn’t look like the correct injector
MOD. E90DSLAFC
01/2016
SER 05456908 66.2
Crosbyman
you really should check-in on the etec owners board I3 section for 90 hps where etec folks gather
Here is a list from GEB...
5010221** AAA and Newer 3 Cylinder BIP Injector
** Previously Part # 5008886.Now Part # 5010221. N.B. 2013 and later In line injectors have 35 degree nozzle angle and these injectors cannot be switched with 2012 and earlier without possible damage to the engine
E-TEC INLINE
FUEL INJECTORS
Part Number Year Application Notes
5010219 2009-2011 15HO-25-30HP
5010220 2012 & Newer 15HO-25-30HP
5006220 2004-2007 40-90HP Voice Coil
Injector
5008826 2008 & Newer 40-60HP/MFE BIP
Injector
5006220 2004-2007 75-90HP Voice Coil
Injector
5008826* 2008-2012 3 Cylinder BIP Injector
*Different nozzle angle compared to 2013 and later Inline Injectors
** Previously Part # 5008886.Now Part # 5010221. N.B. 2013 and later Inline injectors have 35 degree nozzle angle and these injectors cannot be switched with 2012 and earlier without possible damage to the engine
EMM
587612* All 15HO-25-30HP *Superseded by
587489
587489 All 15HO-25-30HP
586759** 2007 & older 40 and 50HP **586862 can be
substituted
586862 2006 and 2007 60HP
586759 2007 and older 75/90HP 3 cylinder
587281 2008 - Current 40/50HP
587283 2008 - Current 60/65HP
587283 ALL 55- MFE
587283 2008 - Current 60/75/90HP 3 cylinder
_____________________________________________________________________
E-TEC 60 Degree
Fuel Injectors
5007042 2007 - SUC & SUR 60 Degree ALL Port Side-Voice Coil Injector
5007043 2007 - SUC & SUR 60 Degree ALL STBD Side-Voice Coil Injector
5007179 2007 - SUF 60 Degree ALL Port Side-Voice Coil Injector
5007180 2007 - SUF 60 Degree ALL STBD Side-Voice Coil Injector
5007764 2008 thru Current 60 Degree ALL Port Side-BIP Injector
5007765 2008 thru Current 60 Degree ALL STBD Side-BIP Injector
EMM
586707 2006 - 2007 115-200 HP Used on engine with
60 Degree Only Voice coil injectors and CD
Ignition
586982 2008 - 2009 115-200 HP Used on engines with BIP
115 (F)Suffix Injectors and CD Ignition
587130 2009*- AAA 115-200 HP Used on engines with BIP
Injectors & “IDI” Inductive
ignition Not 2009 115F Suffix
587155** ABA - Current 90HO-200HP **587130 & 587155 have
internal component changes
Wrong EMM can cause T&T to
operate when EMM powered
with key On.
Note.EMM #0587130 Replaces EMM#0587000, 0587048 and 0587067
E-TEC 90 Degree
FUEL INJECTORS
5006221 2005-2007 Port Voice Coil Injector
5006222 2005-2007 STBD Voice Coil Injector
5007764 2008-Current Port BIP Injector
5007765 2008-Current STBD BIP Injector
EMM
587155* ABA and Newer *587130 and 587155
have internal component
changes. Wrong EMM
can cause T&T to
operate when EMM is
powered with key On
587131 MY11-AAA 3.4L EMM has circuit for
power driven rear oiler
587130 2009-2010 3.4L
587130 2009-AAA 3.3L
586982 2008 Only 3.3L
586707 2007 and older
Note EMM #0587130 Replaces EMM #0587000, #0587048 and #0587067
__________________
1tomtom
E-TEC INLINE
FUEL INJECTORS
Injector
Injector
Injector
EMM
587489
substituted
587283 ALL 55- MFE
E-TEC 60 Degree
Fuel Injectors
EMM
Ignition
with key On.
E-TEC 90 Degree
FUEL INJECTORS
EMM
changes. Wrong EMM
can cause T&T to
operate when EMM is
powered with key On
__________________
Am I blind but I don’t see any listing for a 2016 etec
Crosbyman
2013 and later means 2016 ???
check in with the ETEC folks unless somebody here canbe more specific
see case search dealing with this series of post 2013 injectors for IN LINE 3cyl.
