Re: 90 hp force is it worth rebuilding?
Disassembly outside is going to be more difficult because you will be wearing gloves and heavy clothing. And at this time of the year you will need some brass balls--uh, Christmas ornaments. Other than that, not much effect. Some bolts may be corroded a little and may need heating anyway. Once you get the block off the leg, it only weighs about 100 pounds. Bring it inside to finish disassembly.
I get timed out on here all the time. Next time it happens, if you are not redirected to log in, go advanced. That should give you a log in window without losing your data. If that doesn't work, then write part of it and post, then edit a couple of times to finish.
