90 hp Force L drive will not rev up past 3,000 rpm under load
rrgenter
I have a 1990 Force 90 H/P L drive that will not go past 3k rpm under way and will not plane out. Comp check is good, fuel pump is cleen. Prop is correct. Please help<br />Thanks Ron
rrgenter
Re: 90 hp Force L drive will not rev up past 3,000 rpm under load
Just for ha has, will a force outboard power head fit on a L drive?<br />Just wondering in case my poer head cost to much to repair.<br />Thank You
roscoe
Is this boat new to you?<br />Have you ever got it to plane?<br />Is this a new problem?<br /><br />Check for spark on all 3 plugs.<br />Fuel to all 3carbs?<br />Do the plugs all look the same? with a slightly oily/sooty appearance?<br />Or is one of them very oily, or very dry?<br /><br />Some Force powerheads will fit as a replacement, but I don't know which one(s).
peacekeeper6
check the grounds to the could packs, check and make sure the trigger is connected correctly<br />when i had that problem thats how i fixed it those two things.
rrgenter
The boat is new to me, I got it hot when the water pump went.I replaced the pump, head gaskets, and exhaust gaskets. Have no idea if it ran ok before. never got it to plane.<br />How do u check for fuel at csrbs?<br />Any help would be appricated<br /><br />
Originally posted by roscoe:<br /> Is this boat new to you?<br />Have you ever got it to plane?<br />Is this a new problem?<br /><br />Check for spark on all 3 plugs.<br />Fuel to all 3carbs?<br />Do the plugs all look the same? with a slightly oily/sooty appearance?<br />Or is one of them very oily, or very dry?<br /><br />Some Force powerheads will fit as a replacement, but I don't know which one(s).
roscoe
Gas should flow from the fuel line, and the carb float bowl should be full of gas.
peacekeeper6
hold ur hand over the open end of the carp, or hold the choke shut by hand, gas should drio out of the carb when let go if it doesnt start. make sure all grounds are hooked up and all coild wires are correct.
rrgenter
Originally posted by roscoe:<br /> Gas should flow from the fuel line, and the carb float bowl should be full of gas.
both are good but still will not rev over 3k rpm
rrgenter
How do you check fuel pressure at pump and at engine?
roscoe
Fuel pump only puts out a couple # of pressure. (2-4 #)<br />Only way I've checked for fuel pressure is to remove line going to carbs and hold it in a cup. Then crank the engine over and watch to see if gas comes out the line.
K Hultgre
What are the compression numbers?<br /><br />Have you checked to make sure the timing is advancing?
rrgenter
#1 115 lbs<br />#2 110 lbs<br />#3 120 lbs<br />How do you check timing? The rod under the flywheel moves with the throttle.<br /><br />
Originally posted by Kevin H.:<br /> What are the compression numbers?<br /><br />Have you checked to make sure the timing is advancing?
peacekeeper6
get a timing light, only way to do it. make sure u ground the plugs though or u will blow all ur cds.
cyberman59
There is also the possibility of the prop being the wrong pitch for the engine. I have a 90hp and the prop supplied with the engine was a<br />3 blade/21 pitch. This prop would allow only 4000 rpm, not the 5000 to which the engine should rev. Changing to a 4 blade/17 pitch gives me a max of 5000rpm and the ability to quickly reach planning speed.
rrgenter
I pulled the reeds and a few of them u can see light thru, and one seems bent. can this be my prob?
peacekeeper6
yes, damaged reeds can cause the engine to not perform at peak, i suggest a timing light, just to elmiminate it, autozone rents them.
rrgenter
The prop on this is a 13 1/2 X 19 pitch. Does this sound right? The boat is a 90 h/p L drive and is 17.5 ft.<br /><br /><br />
Originally posted by cyberman59:<br /> There is also the possibility of the prop being the wrong pitch for the engine. I have a 90hp and the prop supplied with the engine was a<br />3 blade/21 pitch. This prop would allow only 4000 rpm, not the 5000 to which the engine should rev. Changing to a 4 blade/17 pitch gives me a max of 5000rpm and the ability to quickly reach planning speed.
rrgenter
I am going to try that this weekend if out of time then what? Jeeze I feel dumb. :eek: <br /><br /><br />
Originally posted by Boater Dude:<br /> yes, damaged reeds can cause the engine to not perform at peak, i suggest a timing light, just to elmiminate it, autozone rents them.
rrgenter
how do u tell what prop is right for my 90 hp? <br /><br /><br />
Originally posted by rongentersr:<br /> The prop on this is a 13 1/2 X 19 pitch. Does this sound right? The boat is a 90 h/p L drive and is 17.5 ft.<br /><br /><br />
peacekeeper6
if it performed good before then the prop is right.
