This is probably a simple fix but it has us stumped. We have a 1990 90hp Force Outboard. Last week, first trip of the year, it accelerated and ran well for about 100 yards, then lost the waterpump impeller and impeller housing, the motor shut down and wouldn't run. Installed a water pump kit, motor will now start, is pumping water but it won't rev over 1500rpm. It's firing on all 3 cylinders, but just has no power. Is there a safety mechanism on this unit for a case when the water pump malfunctions which would cause the timing and acceleration to be affected? Managed to get it to run in reverse out of marina, but while shifting into neutral and then into forward, the motor dies everytime. Able to manually advance timing and throttle in neutral to 4500rpm but the motor dies when trying to use controls.
