My 1981 90 HP Johnson will stall when idling with the engine tilted up.  It runs fine at all open throttle speeds.  Idle at trimed down position is a little rough.  I need to squeeze the primer bulb to start after it stalls with the engine tilted up.  About 1-1/2 years ago the fuel pump was replaced and the carbs were rebuilt.  The replacement float needles did not have rubber tips like the old ones.  Thanks for any advice.   Bert.
