90 HP Johnson Thermostats, 2000 year model
b4odmnpl
My V4 is apparently overheating as the the long single alarm pops off after about 1 minute of run time on muffs or in the lake. 2 cylinders are too hot to hold your hand on and the other 2 cylinders are warm/not to hot to touch. Plenty of water pressure from the water pump as there is a strong water stream exiting the pee hole. I think the thermostats, or at least one of them, is not functioning properly.
What is the correct replacement thermostat kit for this engine?
Txs!
Chris1956
Re: 90 HP Johnson Thermostats, 2000 year model
Look up parts on Crowleymarine website. The parts are likely avail here in iBoats, ebasicpower and lots of other places.
