90 hp. nissan
greg daigle
i have a nissan 90 hp that wont let me get about 3,000 rpm's starts missing whats the problem
pvanv
Re: 90 hp. nissan
What is your actual model/serial?
If it's an old NS90A, when were the carbs and whole fuel system serviced? What oil are you running? What is the plug condition? Is link and sync set correctly? Have you verified the primer hose and tank pickup don't have any vacuum leaks? Are you getting any warning lights or beeper?
greg daigle
Re: 90 hp. nissan
yes it is an older nissan and the oil inj. has been removed im using mercury oil plugs are new and linkage is set correctely im a certified suzuki mech. this one has me stumped thanks for your help just dont know much about the nissan
TOHATSU GURU
Re: 90 hp. nissan
Yes, it does. You need a manual to run the ignition system checks.
TwoRivers
Re: 90 hp. nissan
Greg,
Welcome to the board and good luck.
I sure hope this board helps you get your problem solved because we can sure use a good Suzuki mind over on that side of the board.
Hope you'll stick around.
greg daigle
Re: 90 hp. nissan
i came in on outboards after the fourstroke came out just not too good on two strokes i have all equipment for suzuki four strokes
pvanv
Re: 90 hp. nissan
I would start by using 003-21036-1 SERVICE MANUAL, 3 & 4 CYL, 2-STROKE $45.00 as a guide (available from any dealer -- even a few forum members, even me...) and do a thorough ignition system test.
TwoRivers
Re: 90 hp. nissan
Good to hear you got it fixed.
Thanks for following up the thread.
