Hi,<br /><br />I have a 1984 90HP Rude. I just installed 2 carb kits, hoping to solve this problem, but it didn't. Also cleaned fuel filter, replaced all the 2 cycle oil, & 4 new spark plugs. When I put the boat in the water, drop the motor and try to start it, it gives me 10 minutes of grief. <br /><br />The motor turns over fine, and fires up, but dies immediately. Here is the procedure I use: <br /><br />1) Squeeze the fuel primer bulb until hard.<br /><br />2) Turn and push in on the key to activate primer for 15 seconds, before first attempt to start. I hear the click from the primer solenoid ok.<br /><br />3) Lift the throttle lever 1/2 way<br /><br />4) Turn key and listen to motor pop and then die. <br /><br />Repeatedly play with throttle and key primer for the next 10 minutes, as the motor starts, runs a few seconds then dies.<br /><br />As the motor is barely sputtering, if I raise the throttle lever fully, the motor will not rev up beyond 500 RPM. It just sits there and coughs and sputters until it gets warm. Then it will slowly increase in RPM.<br /><br />After 10 minutes of this, the motor runs mint. The throttle lever will now raise the RPM's big time, maybe to 4,000. I can then start and stop, no problems once it's hot. Even after being shut off for an hour, it still starts right up. Seems like trailering the motor in the up position kills it.<br /><br />Where is the choke on this thing ?<br />
<br />Any ideas ?<br /><br />Thanks,<br />Paul<br /><br />What could be wrong here ?
