Re: 90 hp rude won't run--drains battery
OBJ--thanks for the reply. <br /><br />I've has this motor for 17-18 years . Treated me real good, so far. I checked under the flywheel as well as all the wiring on the entire motor. Everything looked real good. Also the battery did have a good, full charge. Yes, it does have TNT.<br />One thing I failed to mention is, after the motor shut down,and would't restart for the third time, I felt the positive terminal on the battery, and it was extremely hot, which lead me to believe the alternator failed and the motor sucked all the juice rapidly from the battery. That's about all I know. Any other info, Ill be happy to disclose for your input. You guys are great!
