Re: 90 hp starting issue
thanks for the links.as far as the carbs dont really know.just recently purchased boat (3 weeks ago)
theres your answer...
since you just got this motor i recomend changing or check the lower unit oil..... decarb(use link bellow) or rebuild carbs.... change water pump ...
not very important but when you have money and a chance change the spark plugs...
anybody missing anything?
when you try to start the motor after boat is warmed up do you have to give it some gas to start it, to advance the throttle? i would also check the timing at idle
good luck
