Just bought this boat - 1992 Johnson 90 HP - 1st things 1st tossed the water pump and Stats - engine runs like a champ - smooth idle smooth high rpm, plenty of power -<br /><br />OMC Tach not working - 12V at Tach Purple and Black poles - good read <br /><br />My question is with the reading of pulse - From the searches I have done it seems with a Multimeter set on the AC Scale of (15) I should read 5 to 7 volts with black to ground and red to Gray wire - I get zip on the multimeter - I then went to the terminal board on the engine. I disconnected the feed to the tach - I checked the gray from the rectifier again with the AC scale set to 15 & read Zip - I moved the red pin of the multimeter to both yellow wires on the terminal board & read 7.5 Volts AC and 11 Volts AC - I'm not sure what I should be reading on those - <br /><br />Any ideas - anything I'm doing wrong here ????
