Valley Boater
- Oct 1, 2009
- 80
This is my third attempt to post with no expert advise yet so I'll try to reformat as I've worked on it a little more. I've recently acquired a boat with a '90 Johnson 40 hp (J40ELESR). The motor doesn't have electric tilt. The motor is stuck in the down position & I suspect the problem is the tilt assist release. I removed the lower cross bolt which diconnects the tilt assist cyclinder and can tilt the motor up.
The starboard tilt lever doesn't seem to move the release cable very far, only about 1/4". Is this the possible problem? The You Tube attachment shows the degree of movement.
As shown in photos, the cable shows some fraying of the outer rubber casing. Possible problem?
I feel that I need to remove the cable and see how far the center wire is traveling against the tilt cyclinder. Do I remove the top, outer nut to remove the cable from cyclinder? Also, what is the trick to remove the cable where it is attached to the motor (first photo) at the other end? I'm not sure what part to pry to get the black plastic "holder" off the motor.
All suggestions are greatly appreciated.
Don
Don
