90 Mariner fuel problem
talsum
I have been posting problems with my 1995 Mariner cutting out at WOT. I have inspected and replaced most of the fuel system to no avail. I did the Seafoam treatment and noticed the lower carb (3 carb motor) had fuel seeping out of it while the top 2 were sucking in air. Is this a float needle problem? Will this affect performance at WOT? By the way, when doing the Seafoam it smoked a lot. Must have had lots of carbon in it. Haven't had it out on the lake yet to see if the Seafoam helped.
studlymandingo
Re: 90 Mariner fuel problem
Sounds like a float sticking or damaged or a needle that is not seating properly. The seafoam does make it smoke lots!
talsum
Fixed it! Must have been a stuck float. I took the carbs apart last year but it still wouldn't run right. Recently I took the lower carb out, cleaned it up, and reinstalled. Now it works. Go figure. Thanks
talsum
J BLANK
Does this Seafoam help the carb's as far as cleaning them if sprayed into the enjine at a high idol?
