You must have 12v at the output stud, this indicates your connected to the battery. If you don't, find out why.
For testing you can connect a wire from the alt output stud directly to the battery, turn the key to "ON" read the battery voltage eg: 12.6. Start the engine and the reading must be greater . This indicates a charge .
