90 Sea Ray Vibrates And Clunks
ROBYABLIND
I have a 90 searay 180 i/o mercruiser v-6 ,power steering,alpha 1 out drive. the issues i have are two, 1 the steering appears loose and sloppy - especially at low speeds, found play in cable to rack connection- is there an inexpensive way to take up play?question 2 when rear drive is disengaged and rpm in increased i get what seems to be an unusuall amount of vibration - ok when cruising.. help? thanks , rob
Re: 90 Sea Ray Vibrates And Clunks
Love The Forum, Help?
Ayuh,.... So you've been doin' some Readin', huh,..?? We'll Gladly give you a Hand,...
Right after I point out the 2 cardinal Rules you broke in this post,....
1),.. I believe you have the keyboard Cap-Lock on,... That's why every word is Capitalized...
Typeing with the Cap-Lock on it considered YELLING on forums,... And Nobody likes to be YELLED at....
2),.. We can't Help you til you tell Us, Who's motor,+ Who's drive,...
We don't give a danm about the boat most of the time,...We do Motors,+ I/Os in this particular forum...
Sooo,... Fill in the blanks,+ We'll find the Answers....
Good Luck,+ Welcome Aboard,.....:)
Btw,....
Or Is The Rumor True.....boat = Break Out Another Thousand Really True???
Ayuh,... As True as the grass is Green,+ the sky is Blue.......
ROBYABLIND
okay, no yellin this time.......:D 4.3 engine mercruiser - gm v-6 alpha 1 out drive to name a few..
