Phishnvdub
- Jun 16, 2012
- 46
Here's the background. This motor came on a 17' Starcraft Medalist 1700 fiberglass open bow I purchased a few months ago. Idled good on muffed so I thought everything was good. Had to a Marina for a water pump and to be looked over. Did pump and idled on muffs, said all was good and sent me on my way. Ever since then I have been battling with this motor to run right.
At first it would die at idle. VRO was leaking at the seams so I deleted it, blocked off pulse port and installed a fuel pump in the stock spot where it mounts against the crankcase. Seemed to help idle. Tried to test run in the river and would die in gear. Finally got it to go and ran like crap through the whole RPM range until WOT. Turns out the head gasket was blown between the rings that seal the cylinders and started letting water in lower starboard side.
To make a long story short. I replaced both head gaskets as the diverters in the one side were swollen so I wanted to do the other side to be sure. After a lot of research on here I have figured out the previous owner over heated it at some point. A couple spots had bubbled paint and some wire casings were melted. Things I didn't know to look for when purchasing. Also replaced cam roller and follower one on side of carbon and the other that rides in the groove in I think the throttle arm as the outer plastic sleeves were missing.
Here is where the motor stands as of today. It idles better on muffs. Is a little rough but does not die. Actually a little higher than before. Compression is low about 100# in top two cylinders and 90#,95# in bottom two. With this in mind I took it out for a water run today. Died when put into gear again. Somehow I got the fast idle lever down and got it to go. Once over idle in gear it ran like a beast through the whole RPM range. Up on plane in literally seconds. GPS said top speed was 42MPH. I would have thought with compression being low it would not have the power it did. From almost a trolling speed to WOT there was no hesitation and it ran really smooth. I probabbly ran it for a little over an hour at all different throttle positions and it ran awesome. Just made sure not to bring it to neutral until I was back to the boarlt launch.
Now, I noticed the bottom of the carbs are wet. The lower one more than the top. Looks like fuel bowl gaskets are leaking. Also here is a picture of the plug after some idling on the muffs and the running I did today. I put new in when I did the head gaskets. I am thinking about getting a good service manual, rebuilding carbs and doing anlink and sync then seeing if it will idle better and go into gear with out dying. I definitely think the sync is off a bit. Would I benefit from doing these things, or do the compression numbers make it not worth it? If I can get most of the summer out of this motor I would be happy. Then try to rebuild it over the winter. I have my second daughter due in a little over a month so thats going to kill having time to overhaul any time soon. Really want to get my 4 1/2 year old out on the water. Lol she has been asking for weeks and waiting very patiently to go out on the new boat. After running it today I am hoping there is a chance with out a major overhaul yet. I am sure some of u guys know how it is, trying to do things with the little ones that I never had a chance to do myself.
