90hp Mercury outboard running poorly at high speed
brittsinvader
Somebody please help!<br /><br />Boat: 16' Invader Bowrider<br />Motor: 90HP Mercury Outboard<br />Serial Number: 0B108156 Model Number: 1090716<br />This motor only has 200 hrs on it<br /><br />I was out on the boat running 3/4 throttle for about 10 minutes when the boat suddenly started feeling sluggish. (probably over heated due to failed water pump) I Immediately put her back on the trailer.<br /><br />Following is a list of everything done since then:<br /><br />Step 1. Complete new water pump (housing, impeller, gaskets, etc.) Definitly needed it, old impeller dry and hard as a rock.<br /><br />idled well ran OK at slow speeds but seemed to miss. no power to plane<br /><br />Step 2. New Plugs (factory Spec NGK-BUHW)<br /><br />Still missing and had no power to plane<br /><br />Step 3. Drained old fuel filled up with new fuel<br /><br />Still missing and had no power to plane<br /><br />Step 4. Checked plugs again. Plug six clean (not firing). Checked power with a meter and traced the problem to the switch box assembly. Replaced Switch box. All plugs now have spark. All Cylinders Firing.<br /><br />seemed to run much better. smoother idle. still no power. I can get it to plane when I'm alone in the boat but only capable of about half the speed. 18mph tops (I've had it up to 46 on glass) seems like its just not getting enough fuel.<br /><br />Step 5. Replaced all Fuel Filters (Inline Filter, Fuel Screen, Auto Blend Filter)<br /><br />No Change from step 4<br /><br />Step 6. Checked Compression all cylinders consistant. aprox. 130's<br /><br />Please Help. Any ideas on what to try next?
JB
Re: 90hp Mercury outboard running poorly at high speed
Howdy Britt.<br /><br />Welcome to iboats. :) <br /><br />You will get much better response in the Merc Troubles Forum. I will move this for you.<br /><br />Good luck. :)
