90hp oil tank leaking
recess
I've got a '95 90hp 2 stroke. I have cleaned and found the source of oil leakage when the enigine sits. I keep the engine in the down position and found the oil level sender cap is leaking where it fits onto the tank.
Any suggestions for a fix or is the entire sending unit/cap going to need replacement?
Thanks
tashasdaddy
Re: 90hp oil tank leaking
replace it or convert to pre mixed fuel.
VRO conversion w/ pump still working
if the fuel side on your Pump is still working it is very simple. unplug the 2 line harness going to the oil tank, unplug the 3 or 4 wire harness, going to the Vro pump. cut and cap the oil line going into the motor. add oil to fuel tank, mix well, then remove fuel line at top carb, catching gas in a container, pump the fuel line bulb until you get premixed gas to the carb. you can tell as it will change color. put line back on carb, and go boating.
