DamianJP
- Mar 25, 2008
- 612
Hey guys
I worked on a early 90's Evinrude 25HP, the model number is now where to be found.
Job went smooth and the telltale went from weak to pissing like a race horse and my friend was happy big time.Been about 3 weeks to a month and just got a call from him he said it started to get worse and now it has "NO" telltale.
So I went over there and pulled the water tube off of the water/exhaust jacket (the one on the side of the motor) and felt exhaust (warm air) coming from the barb fitting the telltale hose gets hooked to. Exhaust is getting into the cooling area somehow.
I first I was like "Oh crap" this is gonna be the first call I get were I somehow screwed a job up. But when I got there I turned the flywheel and heard the impeller move. When he turned the hose on water was gushing from the muffs, when we cranked the engine the water gushing from the sides of the muffs went almost all away leaving me to believe the water pump/impeller job I did is fine because it's sucking water fine into the intake.
I think its either of 3 things.
1) Powerhead gasket (Between head and adapter plate and such)
2) Cylinderhead gasket (Should show a drop in Compression though, will test)
3) Exhaust/water jacket gasket(s) , area on side of engine
I need help to plan my next move to start to figure out what to do so I just dont shotgun parts into an area that is fine.
Thanks guys,
DamianJP
Thanks guys,
DamianJP
