91 19.5 foot superfisherman
mphy98
Anyone here know of a wiring diagram for this one? Anyone have a good dash switch plate? Mine is cracked by the screw holes, a minor thing but I like to make it look good. I am replacing the old fuse plate as the bakalite (spelling) was old and cracked out. Thanks in advance, BoB
mphy98
Re: 91 19.5 foot superfisherman
now a 135 merc, soon to upgrade to a 99 johnson 135 just looking for the dash wiring though, thanks bob
Pugetsound
Mphy I f you are going to replace the main power block you can do it wire at a time Fuse each circut and lable makes future problems a breeze. Make sur the wires are size needed and I would solder all connections. The motor as you know is all in a seperate cable set up , and the rest is fairly easy.
