OK guys.... I have a 91,2hp Johnson I picked up to push my small inflatable around. It won't start. I'll preface this by saying I'm not a motor guy but hopefully you guys may be able to suggest a couple things to check before I take it in for service.
The rope pulls fine, prop spins, and it make the "whomp whomp" sound
I replaced the spark plug
The fuel tank is vented (from the top of the cap)
Gas lever is switched on
It doesn't have F N R, you turn it around for reverse
I'm assuming the bottom of the throttle that has a circular symbol will be neutral and the starting setting.... And the carb is to the right... min is all the way up
sorry if I found stupid but I'm trying to learn all I can from you guys! If you need more info from the motor let me know and I'll get it asap!
Thanks a lot!
Thanks a lot!
