fish4fun42
- Apr 30, 2002
- 3
I had my '91 70 HP Johnson overhauled in 2001. Bored .030" over, <br />new pistons, carbs cleaned etc. Engine was overhauled due to galling <br />in #2 cylinder. Carbs were not re-jetted. Engine has VRO.<br /><br />The boat is now in the shop and the #2 piston has a pencil sized hole <br />down the exhaust port side. #1 and #3 cylinders have 120 PSI compression.<br /><br />Mechanic does not know root cause of problem. <br />This concerns me since I don't want to go through rebuild again <br />if I have it fixed. <br /><br />Questions: <br /><br />1. Do 70 HP Johnsons have a history of #2 cylinder problems? (is it worth fixing?)<br />2. Should the VRO be disconnected since the unit is 12 years old?<br />3. Any ideas as to why the piston burned? advanced timing? fuel starvation? VRO?<br /><br />Thank you for your comments.
