I`ve had this motor for the 3rd summer now.It was not running when I bought it.It had been kept outdoors a lot and was somewhat weathered looking.I could see the center screw was stripped from the housing on the fuel pump.he had the carb re-built twice,still wouldn`t do anything but idle rough.I took carb apart and found black specks.Fuel hose was rotten,he would rebuild carb,use same hose&trash it again.Replaced hose&ball&tank.It cranked right up&had great power.But even right after,and most times you run it it wants to stall at 1st 30 minutes of running.1st it seemed fuel hose ball wouldn`t keep tight,but sometimes even with bulb tight it will stall.you can pop fuel line off carb&it will pump a full stream with each pump.Even used the tank7hose from my late model 8HP&same deal.After that inital stall deal,it will run rest of day without a problem.you can even motor to a spot on river,fish for 5hours,start it up and it will run fine.I just took carb apart last night&it is still clean.This motor dosen`t idle quite as smooth as I would like,but it will troll pretty good.It has 120lbs compression in top,and 116 in bottom cylinder.Thanks for any thoughts,
regards,Dizz
regards,Dizz
