Whats the process to removing the lower unit on a 1991 evinrude 60hp ive heard there are some complications with removing the shaft? By the carbs?
I plan to tackle this in a couple hours, any help is appreciated
No complications there at all.-------Find the shaft that goes across under the carburetors.----------Now on the starboard side remove the hitch pin on the shaft.----Now push that shaft to the port side of the boat.-----Have an assistantant gently move control to forward.--------Shift rod should now be disconnected.
It really does not matter what gear you remove it in !!-----In order to release the shift rod follow post #2 ----Remove the 5 bolts on the lower unit and find the hidden bolt under the trim tab.----Do not turn the shift rod when it is off the motor.------After you are done you will say " that was easy "
