i got my 91 150 force running, it was given to me by my uncle. i took it to the lake and it made a real loud tapping noise so that afternoon i tore the engine apart and found out that #1 piston was very lose inside the cylinder witch was causing the tapping noise. The piston is very scratched but the sleeve and rings are fine. So im wondering if the pistons from my blown 87 125 will interchange
is it ok to use used pistons?
and is there anything else i should check on wile the engine is apart?
Also my uncle told me it was majorly overheated
when he used it so i think thats what caused it.
