91 Force 150 Spark on one cylinder.
Tom Scully
The engine has the Thunderbolt ignition.
The top cylinder is the only one getting spark, and it's alot of strong blue, snapping arcs jumping a 7/16" gap.
It seems like this cylinder is getting the spark meant for the other cylinders.
I measured the resistance of the triggers and they are all within spec at 1250 ohms.
I swapped ignition coil wires, all coils spark when the input from the top cylinder is connected to them.
I suspect that the switch box is bad.
Any input would be appreciated.
roscoe
Re: 91 Force 150 Spark on one cylinder.
I suspect you are right. :(
